So, How Does 2.4Ghz Work?
  • So, How Does 2.4Ghz Work?
    Remembering back to my early days with fixed wing I remember having to fly different color flags at clubs and check I was not using the same frequency and so. Does 2.4Ghz differ?
    Blade 130x
    Blade MCPx
    DX7S
    Yes, the transmitter has a digitally encrypted code that it uses to identify itself. You heve to 'bind' the receiver to the transmitter, so the receiver 'knows' the code, then it only responds to that coded signal.
    Trev
      Gotcha, now the bind and ly thing makes sense thanks
      Blade 130x
      Blade MCPx
      DX7S
        The 2.4 system uses a couple of methods to bind. One is a type of frequency hopping, the other is direct sequencing. Freq hopping uses an algorithm that the rx and tx run concurrently, so that they hop to available frequencies at the same time. Direct sequencing scans for two available channels in the 2.4 band and locks those frequencies between the tx and rx. Futaba run freq hopping, Spektrum use direct sequencing. Either way is as reliable as the next and both use a method of binding so that they cannot be interrupted by other tx/rx combinations
        Trex 500ESP - Scorpion motor, CC ice 75 esc. Spartan Quark gyro, Std Align servos
        Knight Sport - Spartan/BLS251, Hyper 50, 3050's on cyclic, 3D mixer arms
        Outrage Fusion 50 - Viper 700kv, 14t, Align servos, Spartan, 8s, Hobbywing 100HV. Maidened - Love it, set up to fly really smooth :-)
        Gootch 450SEv2 built and flown, very nice heli :-)
        MCPX BL
        MPX Twinstar (In bits!!)
        DX8/Futaba T9CP
        Phoenix
          Nice, thanks Murph
          Blade 130x
          Blade MCPx
          DX7S
            Interesting, thanks murph.
            Is this the same for Spektrum DSM2 and DSMX?
            I cannot get the low down on what exactly is the difference between them!
            Taa
            Trev
            Trev
              Simples, dsmx has a wider range of channels than dsm2 so more models can be flying together without interference.
              Gravity is your best and worst friend!
                Spektrum released dsmx because there was apparently issues with people not getting a connection at IRCHA last year. I don't know how much truth there is in that but they released it because dsmx has more channels than dsm2.
                Del
                Climb-Out
                3D Scotland
                Proud owner of 2 EGS
                  thats DX8 isn't it LOL gonna use that at the field to wind some plankers up.
                  Raptor 30V1 Maverick Head
                  OctoCopter
                  Futaba 14SG
