Guys,
I dont want to cause a fire. I have a fusion LX60b pro charger with the lead with balancing plug to charge 6x mcpx batteries at once.
Im trying to set it up but im not sure i'm doing it right. The stock Eflite charger charges at 0.7 amps. This charger has a setting that goes from 0.1a up to 6.0a. It also has a "C" setting that seems to imply "Capacity" reading the manual.
Am I to set capacity to 1300 (6x220) or just 200? (It only increments or decrements in 50mah chunks, so i assume I should undercharge rather than overcharge?)
The batterys I have are 220mah except one which is a 260, So id assume charging them all to 200 is fine? I dont understand how this works, I'd of thought the charger would sense when the batteries are full?
Id assume I either want to charge 1300mah @ 0.7a or 200mah @ 0.7a but the thing that worries me is if you decrement the mah of the battery it automatically decrements the ampage. You can increase the ampage after but the charger seems to want to charge 200mah at 0.2amps which doesnt seem right to me...
Also any recommendations on discharge current? 0.2a maybe?
Also, when I come to charge the 3000mah optipower packs for my 500, which settings do I want to use for that? 3000mah 22v? (6 cells 3.7v each?) what ampage?
Thanks for help
Thanks for help
