i've seen a few other brands doing batteries for the blade cx2 any ideas which is the best/ for the money
batts for bcx2
Don't know if they will fit the Blade but I bought 3 2S 12C LiPos for my Twister Medevac. They are 28x53x14 mm (the exact same size as the stock JP batteries) but are 900 mAh instead of 800.
They where £2.99 each BUT postage was £11.36 (so I bought 3 to bring the unit cost down to about £7.00)
The new batteries perform a lot better than the stock (1) they last longer, (2) they hardly get warm and (3) they seem to be able to deliver more power before the voltage drops.
I charge them on my cellpro charger and can confirm the higher capacity.
I got them from "cwtco" in Hong Kong via fleabay and they arrived 4 days after I placed my order.Snarf
Scale - Aerospatiale SA 315B Lama, Bell UH-1B Huey, Bell AH-1 Cobra, Bolkow BO-105, Hughes 500E
Sport - Trex 450 SE V2
JR DSX9 | Cellpro 10s | Phoenix
I really rate the DN power 850 mah 15 C batteries, Infact I even wrote a review on another forum. That said I see my supplier has now changed to mega power who also do a 15 C version. I know they have had a bad history with puffing, but mine have been very good, and I have done about 50 cycles on them :Originally posted by spankone View Posti've seen a few other brands doing batteries for the blade cx2 any ideas which is the best/ for the money
I couldn't find a review of any 15C batteries for my blade Cx2 so thought I would do my own;
Initially I was torn between a 900mah battery and the 850 Mah 15 C one. To say I am pleased with the 15 C one would be an understatement. The performance advantage of the 15C battery over the standard eflite li-po's is massive. The best way to explain what they are like, is to compare them to a fully charged standard battery in the first 60 seconds of use. If you give it full throttle the heli shoots up like a rocket. Well the 15C batteries are like that through the whole filght. There is only a marginal decrease in performance after 8 mins or so. When I fly with the standard batteries it is common for me to not be able to pull out of a rapid descent, and to bounce off the ground. Simply because I was expecting more lift on full throttle.
I would argue the point that the motors are more than able of awesome performace, but that the standard batteries can't deliver enough current to satisfy them. I believe the standard batteries are rated at 10 C which means the DN power ones can deliver 50% more current. Additionally they don't seem to get hot after a flight like the standard ones.
I know people have argued the merrits of the extreme motors, but I had no idea a bettery replacement would have such an effect on the full throttle performance of the heli !Oliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
Align T-rex 700e, Align 610 x3, 3g, Spartan 760,Align 650, Bec pro, Castle Creations HV 110A.
So what batteries did you end up buying...who from and at what price ? I might give them a whirl
Cheers.*** CX2 with extra Bling *** STATUS
*** HoneyBee Belt CP *** RETIRED
*** Phoenix Sim ***
*** T-Rex 600e 1st REAL Heli :- GY611 + S9256 + 3*S9451, DX7+AR6200, Revolution 4800 20C 6S, Radix 600 *** STATUS
i bought any yet i have to many hobbies and cant spend money on the all at once
so 15c refers to current and mah is power right?
It's a diesel.
Maximum output PS 170 at RPM 4200
Maximum torque 258 lbs.ft / 350 Nm at RPM 2000
and forever standard
mAh is the capacity (i.e. a 900 mAh battery will provide 900 milliamps for one hour at the rated voltage - 7.4 volts for a 2S pack - 2 cells in series).
The C rating is the RATE at which the pack will deliver current. 1C is the 1 hour rate (i.e. 900 milliamps for a 900mAh pack) and this is the normal charging rate for a LiPo so they take about an hour to charge. 15C means that the pack is capable of providing 15 times the one hour current (i.e. 15x900=13500 milliamps or 13.5 amps for a 900 mAh 15C pack). Of course, it can't do this for an hour and would, in fact, be exhausted in less than 1/15 hours at 13.5 amps (in practise our motors should not be drawing this current continuously but, on the other hand, we aim never to fully discharge the packs so the duration calculation is very rough).
At 13.5 amps and 7.4 volts we have a power of 13.5 x 7.4 = 99.9 watts (i.e. a bright domestic lightbulb).
All this is at steady state of course. If you REALLY want to know when and where all the juice is going, you need to install a logging power meter but I leave that to the people who do the serious pack reviews.Snarf
I got mine from KrS hobbies. They only seem to stock the mega power ones now though? They are $15Originally posted by Bubblefish777 View PostSo what batteries did you end up buying...who from and at what price ? I might give them a whirl
Cheers.
http://www.xtremecx2.com/servlet/the...-CX2%2C/Detail
Boomtown sell the Dn's http://shop.boomtownhobbies.com/cate...c?categoryId=6 They are $20.Oliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
Ok so humour me here for a bit......
There's 2 batteries .... identical in 850mAh and 15c rated ..... yet one is $19.90 and £19.95.....what's the differece apart from 5cents... ? (This is from Boomtown) also I then see another CX2 battery.... rated 900mah rated at 10c ?????? said would give an increase of 10% flying time (since when was 10% of 850 = 50 ????) Anyway..... am I looking for a high 'C' factor (I interpret this as ability to meet demand efficiently) to ensure consistancy for my heli in flight ? i.e. a 10c compared to say a 20c .... if you stress the engine you'll find performance decreasing as the 10c struggles to meet demand ? and what's the "puffing" effect as described on the cx2extreme website ?*** CX2 with extra Bling *** STATUS
*** Phoenix Sim ***
If you overdischarge or even discharge too fast, or just have a defective pack, the cells can puff up. If you subsequently try and charge the battery, it can pop/catch on fire.Originally posted by spankone View Postgood reply guys keep it up
and yeh whats puffing?
I would only reccomend a 15C battery for the blade cx2. It gives loads more power than the standard battery. Simply put the standard 10C battery can't deliver enough current to satisfy the motors. By putting in a 15C battery, it has the same effect as more powerfull motors. You won't be dissapointedOliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
