Throttle pitch curve
  • Throttle pitch curve
    Hi Guys
    What exactly do they mean Throttle pitch curve, i presume it has something to do with the throttle and pitch working on the same stick, but what does it mean, and how do you adjust it?
    I have a Futaba 2.4 ghz Tx.
    Any ideas..
    Yes, you presume right.
    You have one stick controlling two items - so you program your Tx to know what stick position should do what to the throttle or the pitch.
    Which Futaba 2.4g Tx do you have? Is it the 6 channel one?
    | 3D Championship
      Yes, it is a 6 channel.
        What you need to do is press the mode & select key together, select heli mode, then you'll get the heli mixing settings.
        Then you are looking for normal throttle & pitch curve mixing, on the tranny menu the items are marked with: N-TH & N-PI
        I have the pdf file if you want it for a guide?
        Regards,
        Matt
        Mini titan with kit ESC & motor, Tornado LiPo 1800mAh, GY401, 2.4GHz Futaba Radio & 3x HS56hb cyclic servo's + Futaba 3154 tail servo + JP LI-PRO PLUS 5 BALANCER CHARGER with 10A PSU
        View My: E325 Blog : Web Site
        PS3 User Name: applematt ¦ Big up AppleMac!
