Chargers
  • Chargers
    Evening all,
    Are there any chargers on the market that will charge multiple single cell lipos. I have a 120sr and only have the stock charger that came with it. I have just ordered more batteries and would like to be able to charge more than one at a time. The only ones I can find seem to be the top end ones for charging 3 cell and upward lipos.
    Tim
    Just found this on ebay,
    you could make a lead up like the Guy's have for the mcpx batteries
    http://www.ebay.co.uk/itm/Fusion-LX4...#ht_3490wt_902
    New in pack
    #O-FS-LX40
    Designed specifically to charge 1~4 cell Lithium Polymer (Li-Po) batteries
    Reverse polarity protection on both DC input and output
    Display Type: Blue LED: 1~3 Cell - Auto Selection / Red LED: 4 Cell - Manual selection
    Microprocessor controlled charging system
    System Protection
    No battery connected
    Reverse polarity of output
    Wrong cell quantity selected
    Voltage error
    Input Voltage error
    Circuitry problem
    Output connection 4mm socket
    Specifications
    Input Voltage: 11~15V DC / 100~240V AC
    Battery Type & Cells: Lithium Polymer (Li-Po): 3.7v type ONLY / 1~3 Cell - Auto Cell Detection / 4 Cell - Manual Selection
    Charge Rate: Automatic
    1~2 Cell packs 3.0 Amp max
    3 Cell packs 2.4 Amp max
    4 Cell packs 1.8 Amp max (Max 30W)
    Charge Termination: Constant current / Constant voltage
    WEA-TTI-TMFC........
      I saw a mains powered unit in revolution that did six at once, the batteries just slot in the top. They used it to charge lipos for the shop demo helis. Haven't seen it there recently but give them a call, could be you'll get a 2nd hand deal or at least find out where to get one.
      Raptor 30V1 Maverick Head
      OctoCopter
      Futaba 14SG
