hi i,m after the phoenix sim for my blade cx2 to save on replacing blades lol, but which lead do i need to fit the transmitter and has any one got a phoenix sim and lead for sale?
Any good LHS should have it. If not then in online fast lad are good.
www.accurc.com adrian@accurc.com
This is an apple free zone
Dont forget the rcheliaddict shop....I ordered it and it arrived the day after....you dont know what you get at fleecebay!! Use the shop...great service
TC
I am very new to flying heli's as well. I have a Twister 3D and \ Bell Medivac. I have crashed the bell some much I think I have rebuilt about four of them now. I have only just started taking the Twister out side and trying to hover it, but the first few times resulted in crashes.
I recently purchased the Phoenix Sim and have it set up for my Futaba 9C works great. In fact I have the 9C setup for all my flying , Sim, Bell and Twister 3D. The Difference is marked because I am not having to change from TX to TX between each model I am getting lots better much faster. I can even hover most of the SIM Heli's in Phoenix already.
The Best part of Phoenix is all the different Models you can fly, My favourite is the Hues 550N turbine jet. I am definitely going to build a real one once I am flying the twister properly.
Set up was a bit of a pain as I am not quite used to what is required yet but essentially I set up a new Heli model in the Futaba and made custom changes in the Phoenix control properties. the hardest part was working out the throttle because you have to get the pitch setting opposite to the throttle setting otherwise you get the wrong pitch with no throttle etc.
Once I worked that out I was off. have it running through my laptop to a 40 inch lcd telli, only off when Rugby is on.
I brought my copy from eBay. But I have seen the shop here has Phoenix too, and the price is the same. Only extra I needed was the Futaba cable, but I read in the thread Phoenix comes with your TX cable as standard.
thanks dunc,
this helps alot phoenix sounds pretty good i,l have to get saving now and i,l also keep a look out on ebay.
been flying the blade cx2 today and no crashs, i was hovering a few inches of the floor and getting used to the controls before i go any higher just wished the batterys did,nt take so long to charge up mine takes about 1.5 to 2 hrs is this normal.
