Hi again,
Took my new heli out again this morning for more ground testing.
I've now noticed that when the blades are spinning, heli still on the ground, and push backwards and forwards on the stick I can see that the blades go forward and left and backwards and right? I'm assuming this isn't normal but what should I be looking at to resolve this?
Also, my engine. It's an OS max 30 engine. Already run in on another heli and starts and runs lovely. But, sometimes after I've done some ground tests and shut the engine down to make adjustments I have trouble keeping the engine running again without the glow plug starter on it. Within a couple of seconds of taking the glow plug warmer off the engine stops, even with healthy revs!
P.S.: Forgot to mention the glow plug is nearly new. A goodun.
Thanks in advance for any replies as usual.
