eflite blade 450 3d
  • eflite blade 450 3d
    hi does any1 know the settigs for dx6i for a eflite blade 450 3d have used the 1 in the book but still having problems keeps tipping forward abit new to all of this so please help me thanks
    You'll need to tell us a bit more. Isn't the 450 all set up for you when you buy it? There are lots of things that might be wrong if it's been crashed or used in a non standard way. Difficult to know where to start without more information. There is a guide for a Blade 400 at the start of the Blade 400 section. If it's only a slight forward tilt then use a few click of trim. Otherwise make sure that the swashplate is level, all the servos at 90 degrees and all links the right length.
    Blade 130-X, MSR, MSRX
    Phoenix Sim
      Did it come with the dx6i? If so,it should be already set up and test flown?
      Have you had a blade strike?
      If you have,you may have bent the feathering shaft which could cause your problem
      HK450GT Pro TT
      E-flite Blade CP Pro 2
      E-flite Blade Nano Cp-x
      E-flite Blade MSR
      Spektrum DX8
      E-flite Blade 180 CFX
      Phoenix sim
        Its possible this is just a CG issue and you might be a bit nose heavy. You can check this by rotating the head so the flybar is perpendicular to the boom. Pick up the heli by the flybar (either side of rotor head ensuring it is free to rotate). Check to see if the heli tilts forward or back.
        Make sure you have battery and canopy fitted. If the heli does tilt forward/ back try moving the battery forward or back on to get the heli level.
        Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
          My blade 400 when I got it would nose down on lift off. One problem was that I had the stock flight battery pack too far forwards (check as per bolders post above). I needed to move it so it almost touched the motor. Secondly the swash plate was not level from the factory. So trying to take off for the first time and trimming was not fun as a beginner.
          Gaui R5 + 14S + Tribunus 200 + Scorpion 4530/540 + Bavarian Demon Axon
          Gaui X3L + Bavarian Demon 3SX
          Jeti DS-16, Citizen 625
          iMac + AccuRC =
          Member of East Fortune Aeromodellers
          Jeti Sensors and Apps: https://github.com/AlCormack
            yes split 1 of the blades
              but the trim bar looks o.k not bent
                before you fly again
                take off one blade then unfold the remaining one out straight.then with a hex driver turn the feathering shaft and watch the tip of the blade(if it helps put it close to a wall or solid object) the tip should stay stationary,if it rises and falls the feathering shaft is bent.
                  Usually main shaft and feathering shaft get bent. Take apart and roll on glass table surface. Get lots of spares, and flybars. The only things that break are the bits you haven't got spares for. Think of it as insurance.
                  Phoenix Sim
                    would it not just be your battery too forward or could be your blades are out of track,
