Coaxial helis - making them quicker
  • Coaxial helis - making them quicker
    Hi,
    Have a coaxial heli for my girlfriend, it is a mini twister 4 channel. Basically the same as a blade MCX2. Is there any way of increasing forward speed.. perhaps putting a little weight in the nose?
    turn up travel adjust (rate) +100% should make it move quicker, thats if your tx supports this.
    cheers cuppa
    GAUI X7 Beast X V3 (a nice bit of fish!)
    Trex600n Fbl ys56sr BeastX V3
    Trex500Fbl AR7200BX
    Trex500 Apache x4bld BeastX. Trex 600E HIND mil x5bld BeastX
    DX7se
      I really wouldn't go there, they are designed to be stable and easy to fly - change anything and it wont be. I have a mcx2 set up on a dx6i with dual rates, on the high setting it is quite lively - dont think you can do that with the Twister though.
      Gravity is your best and worst friend!
        tie a brick to the front of it and throw it off a cliff
        it will be a lot quicker then
        some blue tack or a paper clip on its nose should make it slightly quicker in forward flight
        over do it and you'll have control issues on the elevator
        Hirobo Turbulence D3
        1/4 scale Vario Bell 47 G3
        1/3 scale Vario R22
        2012 LHC Scale Cup Judge
          Ye , agree with Cuppa as thats what i did when i had a century razor CX . but just turn it up in small increments and test fly because the more you increase rate on a coax ,the more chance you will have of blade strike (where upper blades hit lower blades) hth.
          Twister 3d storm
          MCPX v2
          DX6i
            nice one that made me lol
            GARY
            550E V3 3GX FUTABA SBUS
            450 pro
            FUTABA MZ18
              Ball of blutack in the front of the canopy,will be slow backwards though!
                Originally posted by jackpe View Post
                Hi,
                I put a larger lipo batt in mine makes it a bit more faster
