Hi all, I'm new to nitro. Have a trex 600n and want to know what fuel I should go for and what nitro content.
what fuel?
if you have a local modelshop then see what they stock and go with that. if your learning it doesn't really matter what you burn.
note-if the engine is used then make sure you use what it was ran with before-i.e synth or castor. DO NOT change the oil type if it is a well used castor engine.
anything circa 10% nitro will suffice.
As raptor heli says what your LHS stocks will be fine , 10/15% nitro is more than enough to learn on as long as there is a good oil content which all modern brands of fuel will have360 RC Technologys (Align )
Optipower /Optifuel
3d-ireland.com
