Hi,
What sort of flight duration do you Co-Ax flyers get from your birds? I get about 7 mins from my Twister Medevac using the stock LiPo (which has had quite a few cycles now). I have upgraded with the CNC swashplate and main rotor hub but left the plastic top rotor hub in place (I had a few crashes early on and the flybar popped out each time which saved some shaft damage I guess. The CNC top hub would not allow that).
I did go over the bearings and gears with a squirt of 3-In-One silicone spray lubricant (slippy but not sticky) and have the impression that put my duration up a bit (5%) but that may not be a significant increase. A bit of lube from time to time strikes me as a good idea though, just as long as it doesn't pick up grit etc.
