Hi
I've just replaced the two shafts, four fresh blades and put everything back together launched her and for no adjustments she didn't fly bad at all.
The only thing I haven't replaced is the fly bar which should be arriving in the next few days.
When I had the fly bar off I rolled it along my PC desk, using the end weights and rubber surrounds as the wheels obviously.
What I noticed is as it rolled the centre bobbed up and down slightly as it traveled, is this a clear case of a slightly bend balance bar, and could this in-turn be the reason as the chopper when facing away from you, seems to be in a slow ( tail to the right, nose to the left) spin, plus it drifts to the right a little also.
I've tried everything to adjust things but I can't get her to fly as rock steady as I did on the last refit, yet I've done nothing different, except the blades are new, and on the precious set up one of the top blades had a slight piece missing from near the end of the blade, yet the flight was perfect.
When I lift off she tends to move forward slightly and again with that slight rotation, which previously I had in the bag.
I've only had three test flights with her, so far, don't get me wrong with very slight rudder control you can get by this, but me being me wants it to fly like I had it before.
Any suggestions chaps...please.
