Hi Folks,
Just bought some training gear for my 450 from the web and it came without instructions.
I know it is simple enough: stick a ball on the end of each of the 4 rods, push the inner end of each rod into the central joiner, and fasten the whole lot to the landing gear with tie-wraps.
However, the plastic joining piece for the inner ends of the four rods has 6 connectors at 60 degrees to each other, whereas I was expecting to connect the rods at 90 degrees to each other because thats what I've seen on other pictures.
If I use the connector I've got then I can either have two rods nearer to each other on each side, or two rods nearer each other at front and back. I think side to side will be the best but just wondering if anyone has encountered this before?
