Hey,
I started off a couple of years ago with the first Pico Z toys, then recently bought a Syma 9098 3 channel. So far then so good... but without looking into it too much I have also recently bought a Nine Eagles 260A. The Syma was a synch to fly but presumably the 260 will be much trickier as a single blade? I only found this forum after the purchase and see most start off with the MCX2 which seems like an easier choice. Can I attempt the 360A or should I not even try to fly it?
I appreciate I should have looked into this more but your advice would be aprreciated
thanks
Jack
thanks
Jack
Looking on You tube, they look similar to the Blade mSR which is a very stable little machine, so you shouldn't have too many problems.
