aurora 9 channel t/x
  • #31
    Originally posted by Gymbal View Post
    For anyone thinking of this TX the RX's are on offer for triple packs at around £100! Just picked up three optima 7's from Midland Heli's for £106
    that's good to know, not much more than the 6 channel rx's
    traxxas bandit
    quark sg
    freya
    • #32
      just picked it up today, talk about bling...
      now i just have to learn to fly.
      traxxas bandit
      quark sg
      freya
      • #33
        Did you get the Aurora 9 Gram?
        Dan
        Goblin 500
        | Blade 130x | Blade 180cfx
        Spektrum DX8
        GWR Pilot 2011 & 2012
        • #34
          Dan
          yes mate! having fun trying to program it, i should have stayed in school lol!
          traxxas bandit
          quark sg
          freya
          • #35
            If you get stuck with anything let me know & I'll try and help
            Dan
            Goblin 500
            Spektrum DX8
            • #36
              Also if you can afford it invest in the HP-22 Interface so you can update the Transmitter, Spectra Module & Rx's as the latest firmware allows you to receive Rx battery voltage
              Dan
              Goblin 500
              Spektrum DX8
              • #37
                photos of your tx!!!
                • #38
                  Good choice is very intuitive
                  To set up
                  Mikado Logo 600 3D
                  Evergreen Raptor 50 now R.I.P.
                  Align T-rex 450 V2 gt5 fbl soon controlled by Ardupilot Mega 2.5
                  Trex 600 nitro
                  Hitec Aurora 9
                  PL8 supported by Grant PSU aka "The Black BOX"
                  • #39
                    Like wise dude! Nice though ain't it?
                    Blade 130x - Absolutely fave heli
                    Raptor 60v2 -Full Alloy Head, TT70, JR490T, Savox 1258tg
                    Raptor 30v2 - Pro39, GY401 with S9254
                    Tarot 450 Pro - Platinum Pro 40A, Tarot ZYX fbl with ds520 tail and Savöx cyclics
                    V120D01
                    Hubsan X4 catchaser
                    Aurora 9
                    Phoenix
                    • #40
                      thanks guys, i might just need some help pretty soon, taking the heli out tomorrow and try and bind it, see if i've set it up ok, also got some crows to shoot so might see what they think of the trex...
                      traxxas bandit
                      quark sg
                      freya
                      • #41
                        Don't you want to bind it, check your setup, THEN take it out?
                        V120D01
                        Hubsan X4 catchaser
                        Aurora 9
                        Phoenix
                        • #42
                          funnily enough, it came already bound to the rx, i did check and re do it just in case, had to reverse one of the servos as it was doing very funny things, anyhow, now charging, think i've got everything for now, had some fun trying to find out how to set up throttle hold, but tom from pegasus did that when i popped into the shop, while he was at it he set up a throttle speed switch so i can adjust the head speed in hover, now going to play with the expo a bit before i wind her up, fingers crossed ha ha!
                          traxxas bandit
                          quark sg
                          freya
                          • #43
                            ouch! that was an expensive mistake, hmmmm, back to the shop with it all, i think i might have done something wrong.
                            where to start!
                            plugged all the leads into the rx, all numbered so as not to get them mixed up, turn her on and the swash is all over the place, now the flight mode is mode 2, so throttle & rudder lh stick, ail & pitch rh stick, however when i tested it looked like i had throttle on the right and god knows on the left stick, reversed the aileron and seemed to settle, then wound her up but she wouldn't shut down, even with both throttle holds? god knows what i've done, i'm damn sure i put the servo leads in the same channel numbers, and made sure i was in mode 2. OOPS!
                            traxxas bandit
                            quark sg
                            freya
                            • #44
                              Take a pic and post it, someone may spot what you have done wrong
                              x 3
                              • #45
                                well, if i reverse the pitch then the throttle works as it should, but the aileron is reversed, when i reverse either of the two forward servos in any sequence the it all goes to pot and the swash is on the huh, and the rudder moves when i increase throttle. to be honest i'm not in the mood to fiddle with it any more at the moment, probably something simple like two of the plugs crossed over, i'd have thought that they would go straight in with no change from a futaba to a hitech tho, my head hurts!!!
                                traxxas bandit
                                quark sg
                                freya
