I have bought a Sullivan HiTork starter and also a mount & batter pack.
Need to remove the aluminum pulley to fit battery frame end plate.
Having removed the rubber cup, and the nut on end of shaft ... how does pulley come off ... is it press fit?, screw fit - if the latter how do you lock the shaft so you can unscrew the pulley.
I could try pulling it off, but rather check first
x 3
