need a lead
  • need a lead
    hi guys,
    i need an adapter lead to fit my balance port on my imax b6 charger but heres the tricky part my batteries have the balance lead to fit the cellpro 10s,
    so i need either an adapter lead with cellpro at one end and imax (turnigy battery standard balance lead fitting),
    or
    the imax balance plug to solder on to the batteries which are REVOLOUTION (revolectric) 4200 5s,
    i have put this post up before and no replies ..... someone must know cause i cant fly without it .
    all the best
    steve
    If your not flying .....then make sure you crash with style
    Hi.... I suspect the connector you need for the imax is a JST-XH.
    You would have to recrimp the ends but you can get these on ebay.... Ill find a link....
      Ebay link -
      10 - 6 Way JST XH Series PCB Connectors | eBay
      The connector on your pack..
      And just swap them 1 for 1, But you will need to recrimp the ends.
      Hope this helps
        See http://www.rcheliaddict.co.uk/beginn...nce-leads.html
        Neil H: Certified compatible.
          thanks for the replies guys, not really understanding the last link, as to what im supposed to buy and from where? lol but yep this is the connector that fits the imax just need a name for the one that fits the cellpro 10s then i can just make a lead up myself,
