futaba 6exh and raptor 30 setup help
  • futaba 6exh and raptor 30 setup help
    hi i need help setting up a raptor 30 with a futaba 6exh tx please
    ok... need more info tho. what do you need to know?
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      hi pitch setup tail pitch stuff like that
        best thing with the pitch is to set it up mechanically. get it close like that and only do minor (preferably none) tweeks in the radio.
        very few use different pitch curves in different flight modes or weird shaped curves.
        what level of flying are you at?
        method of tail setup depends entirely on what gyro and tail servo your using.
        Ade
        www.accurc.com
        adrian@accurc.com
          hi the gyro is a sl 420 csm that what im having troble with setting that up
            what servo are you using with the 420?
            Ade
            www.accurc.com
            adrian@accurc.com
              hi its a futaba s3010
                right... the 3010 was never designed to be used as a tail servo and will not be helping you get it setup nicely.
                its worth spending out on a 9254 for it. However im not the biggest fan of CSM gyros they tend to be a little finicky to get setup right. so it might be easier in the long run to sell the 420 and buy a 401/9254 combo for about 150ukp.
                Ade
                www.accurc.com
                adrian@accurc.com
                  Its the best value for money heading hold gyro available,
                  Its on my raptor 30 for sure.
                  With high frequency digital servos now becoming the norm the GY401 has a DS (High pulse rate) switch for maximum response when used with digital servos. A key requirement for todays modern gyros.
                  Hey with your Futaba EX you even get an extra function setting for it, just cant remember what it is, hehe.
                  your looking around £159.99 but its worth every penny,
                  and for the rappy 30 do a boom mount.
                  Dave,
                  Eagles fly high but tortoises dont get sucked into jet engines..
                  Raptor 30 V2 - Grounded.
                  Blade CX2 - Overhaul.
                  Trex 450SE V2 - Coming soon.
                  New DX6i - yay
                  Phoenix R/C Sim.
                    bravedave. no need to boom mount the tail servo. the metal wire works great IF you get the pushrod supports in the right place.
                    the key is to get the front one as close to the joiner on full left as you can, adding an extra support helps a lot too.
                    Ade
                    www.accurc.com
                    adrian@accurc.com
