a big thank-you
  • a big thank-you
    just to say a big thank-you to everyone thats been helping me out with my heli build, i'd just about given up with the cyclic servo issue but having done everything it occured to me that i had done a mode mod on the tx after checking back thru everything i realised i had not set it after i swapped it therefor causing the throttle stick to actually still be the pitch hence why it was impossible to hold the swash level as it was actually the pitch!!!!, its amazing how close you can get everything to work by adjusting servos, sub trims, end points travel etc im just glad i never connected the motor as that could have been very painfull as the right stick as you know is centered which would have been 50% throttle!!!!,
    i only stumbled apon the discovery when i went into the monitor setting and realised.......
    so once again thanks for all your ideas and suggestions
    especially TIDDLER as you've stopped me taking a very big hammer to the heli
    If your not flying .....then make sure you crash with style
