I am having a problem with my swash plate/ left aileron servo
in normal throttle my heli flys great tracks true and responds to all inputs
when i flick into idle up 1 i notice the left aileron servo moves up a fraction (2 mm ) and also if i then flick throttle hold on still in idle up it moves upwards the same again ?
this first came to my notice on my first flight yestarday when whilst inverted in idle 1 my heli needed a slight right stick input to keep it level ? my last flight a week ago this problem was not there at all
my set up is Align BL 600 motor Hobbywing 100a platinum pro ESC, DX 7 RX AR 7600
using thunder power 5000 lipo·s running idle up 1 and 2 at a flat 85 %
PS i have tried swaping the 2 aileron servos around on the RX but the problem is still there
