Deans Connector
  • Deans Connector
    I am thinking 'Deans Connector' for the electrics on my 450S. Is this the correct way to go. Are there better options. Do the Deans' have a way lock themselves connected, so that they do not come apart during flight???
    T-Rex 450S - Just needs fine tuning now
    Phoenix Sim.
    Spektrum DX6
    Picco Z
    Classic AS800
    Definetly the best imo. Don't worry about them coming apart in flight, it's hard enough getting them apart on the ground!
    Make sure you put the female on the lipo and there's virtually no way they can get shorted by mistake.
    Ian
    Knight 3D
    Velocity 50
      they have a sort of spring load on the male side that gets squashed as you push it in to the female. they wont come apart! i use them on my T-Rex 600e without problems.
        with out doubt they are fantastic connectors i have used them for quite a while on all different planes etc you cannot short them out unless you really want to and there is no chance they will come loose in flight, as said before chuck the female one on the pack
        T-Rex 500 ESP FBL, BeastX
        8FG Super
        MCPX with DX6
          Word of warning, I had a couple where the spring had flattened out and it kept interupting the power and resetting things, thought it was a wonky gyro for a while until we noticed the connectors were kinda loose. Still the best to use tho, and can take almost any current you can push thru them
          Velocity 50
          Synergy N5
          Fury 55 FBL
          Trex 700
            Thanks all.
            Just ordered a few. :-)
            Phoenix Sim.
            Spektrum DX6
            Picco Z
            Classic AS800
              Good Good they are great might put a set to the test at work and see at what current they start to fail could be interesting
              8FG Super
              MCPX with DX6
                Nothing to do with this thread exactly. Just reminded me of a job option I may just give a miss :-)
                [ame]http://video.google.co.uk/videoplay?docid=-658404692476270576&q=powerline+checking&total=1&st art=0&num=10&so=0&type=search&plindex=0[/ame]
                Phoenix Sim.
                Spektrum DX6
                Picco Z
                Classic AS800
                  Make sure you get the proper Deans ones.
                  There are some cheaper copies out there.
                  Had one set that I had to use 2 pairs of pliars to get them apart
                  Binned them pretty quickly, and got the Deans, use them on all my packs now, superb, nothing better.
                  Align T-Rex 600n Pro (Now with 3GX)
                  Align T-Rex 500CF(Gone)
                  Align T-Rex 450 Pro
                  T-REX 250, had it since crimbo(bloody tail) want to smash it with a hammer
                  T-Rex 700......STUNNING (Thirsty) (Now with 3GX)
                  No plank flyers were hurt whilst making this post
                    Now ya tell me !!!!!!!!
                    Phoenix Sim.
                    Spektrum DX6
                    Picco Z
                    Classic AS800
                      Get them from Inwoods.
                      £3 a pair (inc heat shrink)
                      Align T-Rex 450 Pro
                        'Heat shrinks'!!! Now I hope mine come with some. Pack of 3 (no jokes) from revolution.
                        Phoenix Sim.
                        Spektrum DX6
                        Picco Z
                        Classic AS800
                          When you get round to installing them, there's a fantastic instruction video by 'Finless' Bob on how to solder Deans Connectors. I think all his videos are posted on Helifreak.com and you have to register to see them, but it's worth it.
                            Just get your iron nice and hot, tin each part (wire and connector) then add a little solder to the iron and make the joint.
                            I use genuine Deans on everything, packs, chargers, helis. Great connectors.
                            Just make sure when you solder up male Deans you solder the correct end. it has been known...
                            Cheers - Rob
                            T-Rex 600CF-E * GY601 Gyro * S9251 digital Tail * S3152 digital Cyclic * 2x 4800 Aurorra LiPos * 600L Motor * TT composite 600mm blades
                            3DX-400 Hybrid parts bin special * GY401 Gyro * Robbe 0.054sec digital tail * All CF/Aluminium construction bar plastic main gear
                            Wren MW54 Gas turbine Jet-1 trainer * FF9 Super Radio * Phoenix Sim * Understanding wife * Unhappy bank manager
                              Thanks for that. Shows how its done, and a few good pointers, ike the + and - markings etc. Good video.
                              Phoenix Sim.
                              Spektrum DX6
                              Picco Z
                              Classic AS800
