Stupid question, have you taken bind plug out of rx since rebind?
bind issue
think you need to get your servo's check'd something is pulling a high load and the reciever is browning out and causing the flashing do you have a servo tester or can you borrow one
are you a member of a club and somebody there can take a look ??Kel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
& JR DSX11 ,Phoenix and a fridge full of bottled water
RCHA Courier Services PM for Details
www.parcelshipper.co.uk and www.impactexpress.co.uk
A slow, steady blink (taken from one of my AR6200 manuals) is indeed the Rx telling you that power has dropped below the 3.5V operating voltage.... a brownout. I would suggest firstly that you double check all Rx connections are good and solid.
With the symptoms persisting with the main blades attached, we can deduce there may be binding in the head under load, which in turn is overloading the cyclic servos, causing them to pull too much current and dropping the Rx voltage. Disconnect the servo to swash links and check for binding in the head. I would also advise you to take the main grips off and check the condition of the all bearings, and check for grease in the thrust bearings.
The other possibility is one or more cyclic servos failing. I've never had a failed servo so I can't point you towards specific symptoms, but rule out mechanical issues above first.
Let us know how you get on mate.Steve
ok heres the latest guys, ive installed another esc and have just successfully flown 2 packs through it, the throttle seems to be smoother now as well, if that makes sense, perhaps the esc is gradually breaking down ?Trex 500l Dominator
Trex 450l Dominator
Mcpx blPheonix simdx8
update:Originally posted by loz View Postmy 450 sport has decided that shortly after it lifts off the tail kicks round and the orange bind light begins to flash, i have tried a rebind, different batts, checked and wiggled all the wires made sure the plugs are properly in the rx etc etc, but cant find the problem, the strange thing is i put 2 batts through it earlier this afternoon without issue, then went out with it tonight and the problem returned
any thoughts anyone
so ive changed the esc which seems to have sorted the bind problem, but im still having prob with tail whipping round 90 degs which occurs after about 20-30 secs of hovering, my thoughts are now could it be wires to from gyro/tail servo being all bunched up in the frame and causing interference?? then again theyve always been like that and was always ok, a faulty gyro? ....its doing my nut in lolTrex 500l Dominator
Trex 450l Dominator
As u have put a new esc on try messing about with the gyro settings, had a similar issue and when put the new esc on I had to up the gyro settings.
LeeCrashing is in my blood, were can I get a transfusion
You can never have to many batts
Flasher 500
Trex 450v2
Dx6i
Purfleet Model Helicopter Club member
