Accucel 6?
  • Accucel 6?
    should I buy this to replace my 5yr old Triton?
    eBay - The UK's Online Marketplace
    I only have the 450 pro and I am hoping to get a few more 3s 2200 35c batteries... is this charger enough for those batteries?
    i have one and it charges my 450 and 500 batts fine seems ok for the money
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
      it will charge one maybe 2 with the correct power supply at a time no probs
      GaZzA
      Compass 6HV FBL Telemetery Beast x
      T-Rex 500 FBL Beast x
      mSR
      Simstick
      DX8
        i did consider getting the adapter that lets u charge 2 x 3s batts at a time but was told it wouldnt really speed things up so i just balance charge one at a time which normally takes about 55mins on a 11.1v 2200 mah
        Trex 500l Dominator
        Trex 450l Dominator
        Mcpx bl
        Pheonix sim
        dx8
          I have an Accucel 6 and although I am not an expert have found it to be extremely good. I also charge Trex 500 LiPos with it and have found no problems. I did buy quite a decent PSU with it from the same eBay seller.
          For the money I would recommend it without hesitation.
            Buying a decent power supply does help
            GaZzA
            mSR
            Simstick
            DX8
              Decent power supply doesn't matter with this charger as it is 50W max, it takes a laptop charger, or search online for an imax b6 power supply, with a dc jack, as it doesn't have the standard 4mm banana plugs on it, however I use it for my 450 packs and seems fine
              Kev
                Yep that's all I use a £5.99 12v 5amp monitor psu and it's fine
                Trex 500l Dominator
                Trex 450l Dominator
                Mcpx bl
                Pheonix sim
                dx8
                  huh? how do you use a power supply for this?
                  pic?
                  at the mo, i have an old computer 12v power supply that i hacked to use for my triton charger. the whole thing looks like a bomb! very ghetto!
                    Ouch!! Just seen the addy £27.00! No way. Far to expensive, buy from Hobby king direct. Alternatively pm me I have one used three times and boxed for sale if interested?
                      awesome thanks! will PM you now!
                        oh also.. i found an LCD monitor power supply which is rated 12v 4amp
                        will this be ok to power up either the triton charger or the accucel 6?
                          think u need a 5 amp for accucel 6, look on the bay should b loads on there
                          Trex 500l Dominator
                          Trex 450l Dominator
                          Mcpx bl
                          Pheonix sim
                          dx8
                            ahh poop... i'll have a look around some more.
                            so, the higher the amp on the power supply, the better?
                            what about the voltage? does it need to be 12v? or higher is good as well?
                            thanks
                              thanks
                              im not sure if u can use a higher amp, someone on here will probably know
                              Trex 500l Dominator
                              Trex 450l Dominator
                              Mcpx bl
                              Pheonix sim
                              dx8
