gyro?
  • gyro?
    hi
    can anyone recommend a gyro in the region of £30 for a trex helios 450se i know its not going to be in the same class as the spartan or the futaba gy401 but just need to know the better ones of the bunch in that price range,
    many thanks
    steve
    If your not flying .....then make sure you crash with style
    The Phoenixtech GT9 is meant to be pretty good but a little fiddly to set up apparently >>> GT9 Gyro
    I would still recommend trying to get your hands on a Spartan DS760 (First choice) or an Align GP750 if you can. Having a good gyro makes a big difference to the handling of the heli and is well worth spending a little extra on right from the outset. The GY401 is OK (If a little dated now) But the DS760 is just excellent. There are some things you can get away with by going cheaper, but the gyro needs to be a goodun from the start IMO
    Graham
    Phoenix, DX6i.
    x2
      hi Steve
      you may be able to find a GP750 for that much plus a bit of postage, you may even get lucky and get a 401 for that, but both usually go for closer to £40
      failing that a CSM420 would be fine
      Steve - Instructor and builder for the Paul Heckles school of flying
      TREX 600NSP - Raptor 50 Titan - Trex 500ESP - (Dark Side) 50cc EG MXsR - 50cc 3D hobbyshop Extra 300SHP - 363 Delta - Magnum R
      Futaba 12FG, Phoenix sim and some BMFA Certs
        Phoenixtech GT9 I'd say for the money. OK its a bit fiddly setting the end limits but its not that hard.
        Lynx Heli Team Pilot
          i set up a gt9 on a 500 and it was pretty easy and the tail held very well i was quite impressed as it goes
            As long as the servo movement is sufficient IE ball position on horn then the limits are no problem.
              Gt 9 if you want new or Spartan are popping up . Both great
              Sent from my iPhonings
              Oxy4+, tgy servos, hw60a, spirit fbl on 6s 🤓
              sigpic - Team pilot
