Direct feed
  • Direct feed
    Hi Guys, this is my first post ever, and I am very much hoping you all can help me out,
    I bought a walkera 4 and loved it, couldn’t fly it that great, but never the less loved every minute, sadly it had one to many crashes, and although it could have been repaired, moving house ended all hope of that happening, now a year later settled in, and ready to have another try.
    I have no Idea which chopper to go for this time round, I do know that I want one a little bigger, (electric)
    Is it possible to have some sort of thin lightweight cable running direct from house main socket to a transformer then to the chopper?
    “ I am talking out in the back garden “
    This will allow me to practise lifting, left & right, back & forward, limited movement I know, but I can practice without charging/recharging and there is always the wait in between charges, I think this system would perhaps over heat the motors,
    I can add a lead weight about a mtr from chopper onto the electric cable, this way the cable will stay straight.
    Is this possible?
    Thank You
    Regards
    Gary
    Better to get a sim maybe?
    Or more batteries??
    Ian
    Knight 3D
    Velocity 50
      I couldn't recommend the tethered approach... you only need to reach the end of the cable, and it'd get ugly.
      The sim is a good idea... learn the basics on there. That way you don't break anything real.
      The larger the heli, the more docile it is.
      Not counting my foray into IC heli's, I started out with a 450 size electric, which is quite twitchy and difficult to control compared to my new T-Rex 600 electric which is a big pussycat and much easier to fly.
      Cheers - Rob
      T-Rex 600CF-E * GY601 Gyro * S9251 digital Tail * S3152 digital Cyclic * 2x 4800 Aurorra LiPos * 600L Motor * TT composite 600mm blades
      3DX-400 Hybrid parts bin special * GY401 Gyro * Robbe 0.054sec digital tail * All CF/Aluminium construction bar plastic main gear
      Wren MW54 Gas turbine Jet-1 trainer * FF9 Super Radio * Phoenix Sim * Understanding wife * Unhappy bank manager
        I third the sim approach. It's perfectly possible to learn to hover on a sim and transfer that directly to Real Life. I know at least one idiot who's done it.
        John
          I learnt to fly on a sim first, then when i first tried my protech zoom (smaller than a 450) i could hover it easily
          P.S. a goooood sim is phoenix
            Sim
            Thanx Guys, can someone recommened a good realistic Sim ?
            Kind Regards
            Gary
              Pheonix
              Why is the ground to high
                second that
                  Phoenix :-)
                  Just make sure when you order you let store know which trransmitter you have.
                  T-Rex 450S - Just needs fine tuning now
                  Phoenix Sim.
                  Spektrum DX6
                  Picco Z
                  Classic AS800
                    Phoenix Simulator + T-Rex 600
                    Huge thank you, I have nothing at the moment neither aircraft or controller, all was cleaned out when we moved house, so I start again, I wasn't on-line then so all this help is great, the T-rex 600 is just what I think I want, can you recommend a good Controller ?
                    Will I need the controller to use the Flight Sim,
                    Appreciated..
                      Spektrum Dx7 tx and the phoenix sim
                      Gaza07
                      Trex 500esp 6s Beast-X V3
                      Trex 600esp 12s Beast-X V3
                      A few Multi Rotors
                        a Trex 600 is a 600mm blade (1250mm dia rotor) big heli. Unless you live in a stately home its too big for ther garden. Its also a really dangerous thing if not under control. Best flown at a club field.
                        It is possible to learn to hover a 450 size (such as trex450) in an area half the size of a tennis court. but you do need at least that space. also despite its small size it will bite and hurt you or others if it gets out of control - the blades are doing at least 2400 rpm - so you don't want dogs, cats,kids etc nearby and you don't want it taking a leap into over the fence into the neighbours plot either.
                        Having said that I've flown a lot in my garden and in the field at the bottom of my garden without any problems.
                        As regards batteries - a 450 and three batteries (and two chargers) will keep you going almost continuously. Once charger is enough to begin with as you need to bit of a chill out between flights but it is on the 3rd and 4th flights of the session that progess is made.
                        A trex600 and three batteries as quite an investment as the batteries are expensive!
                          All safety points very valid, but I still maintain a 600 will be easier to learn on than a 450. It's a huge investment though, if you get it wrong! I have flown mine in my garden, but only pootling about, hovering here and there. Gardens tend to shrink rather rapidly when it goes pear-shaped
                          Time spent waggling the sticks on a good sim is very worthwhile. You can learn a lot on there even before you go anywhere near a real heli.
                          Cheers - Rob
                            Expensive-read: outrageous!
                            Raptor 50v2, GY401, S9650, AR7000, OS50 hyper
                            Trex 450 SEv2, GY401, S9257 (& stepdown), HS65MG, AR7000
                            Honeybee King, AR6200, Align RCE500
                            DX7/Orca LiPo
                            www.youre.co.uk www.boughtbrought.co.uk
                              I heard the other day of someone who bought EIGHT 6S1P LiPo's for his T-Rex, at a cost of £1.5k
                              Two will do me, for now...
                              Cheers - Rob
