Well it was inevitable and i got off lightly i think. From the top i replaced:-
(Blade 400 3d)
Feathering shaft
Blades
Bolt through the head(Sheared off)
Flybar
Mainshaft
Servo
Tailboom.
I managed to replace all of these parts with no problems. I set the servo arm to 90deg on midstick and then adjusted the right hand side servo linkage to level the swash plate.
All looks level and even. Flybar paddles levelled up by eye. Ran up without blades in and looked ok. Only thing was a slight vibration at full pelt. Normal? Balanced Flybar by measuring each side. Is there a better way?
Ran up and blades were tracking perfectly.
Took to the park and had a fly, first 30 seconds were perfect then it started playing up. It was unresponsive and i fought to regain control and land it.
When i got it home i discovered the gears on the right hand side servo were now also ruined.(definitely were ok after crash or so i thought)
Possibly the crash weakened the gear or cracked them and it weren't noticeable. The power of proper flight must have been too much for it.
Or was there something i missed? All the parts of the swash, washout block, and flybar cage seem to be free and without binding.
Any thoughts, suggestions?
Tony
(Blade 400 3d)
Feathering shaft
Blades
Flybar
Mainshaft
Servo
Tailboom.
Tony
