Hi
I was wondering if you would be able to give me some advice about a couple of helicopters I have been looking at.
I am new to flying, and am looking to purchase a complete setup and have found a couple of people that have the following available which they are looking to sell, and I was hoping that you may be able to give me some advice on which you feel would be most suited to a beginner, but would also give me the best available kit to continue forward with for at least a year.
They all Raptors, either 30s or 50s. For what I can tell these are basically the same apart from the engine size, is this correct?
The details of the possibilities are as follows:
KIT #1: (1387)
Raptor 50 V2 complete with all servos
Futaba 6exa Transmitter (Optional) - Guessing this would need replacing quickly?
Flight box with Fuel Pump, Starter, Glow stick (Optional)
OS 50 Hyper Engine
G V 1 governor
401 gyro and matching s9254 servo on tail
Futaba 9201 on cyclic
Futaba 9202 on ailoron and elevator
3800 mah battery
s a b carbon main blades
Curtis youngblood carbon tail blades
Curtis youngblood power pipe
Full aluminum head and swash plate
Aluminum gelt guide rollers
Carbon tail pushrod
Carbon base plate
Header tank
Remote glow
All above for £500 approximately or without the starting kit and transmitter for £425
KIT #2: (7615)
Raptor 30 V2 Helicopter complete
TT39 Engine
Zimmerman Muffler
Thunder Tiger Carbon Blades
Unused spare wooden blades
Large capacity Battery pack
Three canopys (see pics)
Instructional DVD's (Rays Authoritative, From the ground up, Beyond the hover, RC model helicopters and From buying to flying)
Futaba FF9 Transmitter all programmed ready to go
Futaba S3001 Servos x 5
CSM HLG 200 Gyro
Futaba PCM Receiver
Onboard Battery Checker
Electric fuel pump
Electric Power Panel
Starter and starting shaft
Glow starter battery
Field Box
Tools for maintenance
PRO PEAK Supernova charger with converted PC 12 volt power supply for Transmitter and heli battery
Charger for Glow Plug Battery and Flight Box Battery
Flight Box is a converted stanley toolbox on wheels
Tacho rev counter for checking blade speed
2 gallons of fuel
Various other parts
All Above for £500 approximately
KIT #3: (2751)
Thunder Tiger Raptor 30 fully assembled.
O.S. Max 32 SX-H Ring engine.
Futaba Field Force 6 6X-FM35 50th Ripmax Special Edition Radio with 5 x FP-S148 Servo and FP-R138DF 8 channel receiver.
GWS-01NP Piezo Gyro.
Reflex Training Software (See below).
3.78 Litres Cool Power Heli mix (15% Nitro) fuel.
R.C. systems training under-carriage.
Irvine power panel which controls the starter, glow-plug and fuel pump.
POWERtorque Series II electric starter.
POWERcell 12 volt 7 Amp-Hour battery.
GEL-CELL Lead Acid battery charger.
Ripmax L-IP142 electric fuel pump.
Thunder Tiger Raptor Series 3801 Extended starting tool.
JP Foam blade caddy.
Ripmax L-IP135 Remote glow unit.
Ripmax L-IP176 In-Line fuel filter (2 pack).
3 x Model Technics Firepower F5 Glow-Plug.
Irvine D-IRVLS1 Glow Clip.
1 Metre of Neoprene fuel pipe.
Wooden hobby box to carry it all in (includes cut-outs for power control etc).
KIT #4: (3590)
OS50 Hyper (blue head)
Throttle jockey
Remote glow
Futaba 401 & 9254 tail servo combo
NHP Carbon main blades
Battery checker
Alloy/Carbon tail gearbox upgrade
Carbon tail push rod upgrade
Full carbon tail fin upgrade
Full alloy head
3-off JR DS811 digital servos with a Futaba 3152 on the pitch
New NimH 2300 battery
Hitec dual conversion receiver CH 78
Selling price is around £300-350 but has no transmitter.
If I need to buy a transmitter, does anyone have any recommendations? I was looking at the Futaba Field Force 9 Transmitter.
Thanks for any help you can give me.
KIT #1: (1387)
OS 50 Hyper Engine
G V 1 governor
3800 mah battery
Carbon tail pushrod
Carbon base plate
Header tank
Remote glow
KIT #2: (7615)
TT39 Engine
Zimmerman Muffler
CSM HLG 200 Gyro
Futaba PCM Receiver
Electric fuel pump
Field Box
2 gallons of fuel
Various other parts
KIT #3: (2751)
KIT #4: (3590)
Throttle jockey
Remote glow
Battery checker
Full alloy head
