d/r expo
  • d/r expo
    sorry if this is another stupid question from me on the dx6i in the d/r expo setting what are the 2 numbers represent(change) if that makes sense
    i.e ailer 70% + 30%
    or ailer 70% = inh
    i know it changes the aileron settings and i think the secound set of figures is the expo and softens it around mid stick(please correct me if i got this wrong) but what do the first set of figures alter
    Hi,
    Expo softens or speeds up centre stick. With Spektrum and JR radios positive (+) expo slows down around the centre of stick travel. Negative does the opposite, it makes it faster.
    Dual rates is kind of a maximum throw switch, I personally do not recommend that you use these on a helicopter. Say if you have the elevator dual rate switch set to 70% down, when this switch is flicked down you will only get 70% throw compared to the 100% when the switch is the other way.
      You ate correct about expo, dual rates alters how far the servo is allowed to travel,
      Edit: beaten by Laurence, plus his explanation is better
      Kev
        thank you so if the first set of figures alter how far the servo will travel what is the travel adjustment for. i understand not to use this for my heli's it is for my
        Sukhoi Su-26xp i want to get a lot less movement in the airlerons i have increased the expo but wandered whether to adjust the travel adjustment and if so should i do it in the d/r expo or travel adjustment section
          Travel adjustment will slow down the overall rate of aileron rolls for instance. Expo shouldn't be used to do this, just for around centre stick feel. It doesn't hurt to use a mix of both .
          d/r is as the name suggest dual rate, so you can flick between them in flight. Travel adjustment is kind of like permanent and more of a set-up choice, this I feel should be set to max just before binding then use D/R to customize how you want it to feel.
            fantastic thank you,now can i blame you later when i kill her lol
            seriously that has helped me so much
              Hahaha, I get that a lot .
              Have fun flying!!
                Have fun flying!!
                isn't flying meant tobe keeping it in the air, i will have fun though, it looks like a reasonable night for it so can't wait
                thanks
                  The values in the manual for suky are actually pretty good
                  Kev
                    i cant find the manual, do you know if there is a online version
                      There is one on the parkzone website, should be a manual, mine was underneath the polystyrene
                      Kev
                        For the SU26 I have found it best to use DR and expo which I use for take off and landing and where I need more precise control. When I want full rates I use 100%DR with a bit of expo (for snap rolls etc).
                        Also a little tip. On the DX6i you can bind all dual rates to 1 switch - There is an option in the setup menu to select which DR switch you want to tie then to. I cant remember what the setting is as I have not got my TX in front of me but ill edit this post with the details when I get a minute.
                        EDIT
                        To set DR to one switch go to
                        Setup List \ D/R Combi
                        You can set the switch to your flight mode switch or to the ELEV, AIL & RUDD dual rate switches
                        Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
                          Ah, that's interesting, earlier I had a couple of flights with mine, and wondered how quick it would turn in dr1, but had to flick all the Damn switches and crashed instead lol
                          Kev
