Pred simulator
  • Pred simulator
    Hi,
    Has anyone got a mini pred flight simulator that works, if so how do you make the sound recorder reconize the controller.
    I keep doing as it says in the instructions but the recorder does not record the signal.
    Many thanks
    Jez
    hi mate have you loaded the one that is fms 2 or what ever it is,
    T-REX V2 SE..........OOOHHHHYYYEEEEA
    3D MINIPRED..........ssh dont tell anyone
    TWISTER...............holy rotata bat man
      Yea but before that you have to record the signal of the transmitter or it wont reconize the transmitter, but i cant get it to reconize it so i cant calibrate it to work with the sim.
      If that makes any sence.
      The tx is conected to pc via the mic socket.
        have you gone into the menu on your computer to turn the mic up,it needs to be at the right volume inside the computer so it pics the noise of the hand set up
          i will try that
            Done that made no difference, do i need to move the joysticks or something do you think
              when i pluged mine into the computer it came up with a picture asking if i wanted to use the mic socket,did you get that,make sure your hand set is on,i then had to do the mic volume,then load the sim,when its loaded load the helicopter and then go into controls,click the bottom one(not key pad)then click calibrate,the blue things should be moving all over the place,then when you move your stick up the blue should go to the top of the bar,then when you move it down the blue bar should go down the bottom,give it a go but if that dont work i dont know what else you can do
                Hi reg,
                I have got that working now and have calibrated the radio but i cant get any throttle up to lift the heli of the ground.
                Any ideas on that one.
                  ye ha what did you do,you will need to revers some of your servos,you might find that the other stick give you throttle,try going full over stick and see if it takes off,it migh be one on the right stick,try up and down and side to side,make sure when you calabrated all your trims were in the middle and all the blue bits went all the way up and down,i need to revers two of mine,ithink you can change what does what in the same place to calabrate,the row of numbers,just change them,iv not worked that one out yet so i just reverse the servo
                  were getting there
