could someone please help me with my tail grrrrrrrrr!!!
  • could someone please help me with my tail grrrrrrrrr!!!
    ok guys, i have a trex 450 sport, dx6i, gp750 gyro and cant seem to get the tail to hold, i set it up in rate mode and can get the tail to just about stay put with a little trim, but then if i switch tx to hh it moves the servo and is spinning to the left, i know its probably just tweaking things here and there which i have been doing (honest) but i just cant seem to get it right, is there a certain procedure i should be doing???
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    just done a bit more tweaking and it seems to be holding, i think ive sorted it, now to crash it and start all over again.
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
      Make sure that in rate mode the pitch slider is in the middle of it's range with the blades in line if you fold them towards each other
        yeh i thought id done all that but it still kept spinning, in the end i just kept adjusting ball joint til it stopped then switched to hh and was sorted, slider still looks central so must have been me as it was obviously slightly off, anyway been and had a go since then just looking at the crash damage now!! luckily just a cheap set of main blades
        Trex 500l Dominator
        Trex 450l Dominator
        Mcpx bl
        Pheonix sim
        dx8
          if its pulling to one side always always do it macaniicly never ever use trim on the tail servo
            yeh thats what i been concentrating on, doing everything mechanically, all my trims are central
            Trex 500l Dominator
            Trex 450l Dominator
            Mcpx bl
            Pheonix sim
            dx8
              how much gain do u have
                gain is 70%
                Trex 500l Dominator
                Trex 450l Dominator
                Mcpx bl
                Pheonix sim
                dx8
                  wow omg 70% , ok , take of the link fron the servo to the tail . next step senter the servo by setting the TX to 0 trim ,now find a servo arm that will allmost be at a 90 degee
                  you know what take a look here
                  Trex 450 Pro build videos - HeliFreak
                  http://video.helifreak.com/?subpath=...gyro_setup.wmv
                  and part 2
                    joined heli freak but cant watch video?
                    Trex 500l Dominator
                    Trex 450l Dominator
                    Mcpx bl
                    Pheonix sim
                    dx8
                      if its piroetting crazy check your gyro settings ,you may have to change position from normal to rev..it is the 3rd function led on your 750.
                      v
                        its ok now thanks, managed to watch that finless bob vid in the end
                        Trex 500l Dominator
                        Trex 450l Dominator
                        Mcpx bl
                        Pheonix sim
                        dx8
