swash mix dx6i
  • swash mix dx6i
    can anyone let me know what the swash mix percentages should be as a begginner with a trex 450 and a 500 using a dx6i, cheers
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    Theres no real figures,50% on the elevator and aileron would be a good start and the pitch is set to how much pitch you want,60% would give you around 10 or 11 degrees.This is a rough figure and with all DR at 100%.
      You'd find it very difficult with full rates and no expo. I use 70% rates and 20% expo with a swash mix of 60% on a 450 clone which is a SE2 copy. Boggy posted some useful advice in the blade400 section. Most of it applies except that the Blade400 and Twister Storm need a higher mix figure on one of the cyclic servos. Extra weights on the flybar was one suggestion. It's also very important how the throttle and pitch curves are setup, as you really want lots of control at hovering height.
      Chris
      Blade 130-X, MSR, MSRX
      Phoenix Sim
        ok well mines on aile -100% elev -100% and pitch +70% so im assuming thats not good then??
        Trex 500l Dominator
        Trex 450l Dominator
        Mcpx bl
        Pheonix sim
        dx8
          Cor,sounds abit much on elev and ail....doyou use dual rates,if so,what sort of % you using?
            yes they are elev + 20% and rudd 15% aile is on INH ?
            Trex 500l Dominator
            Trex 450l Dominator
            Mcpx bl
            Pheonix sim
            dx8
              When i first had a CP heli i used +25% expo on all.I also left all dual rates at 100% and just used the swash mix for tuning.
              Best bet is to do the above and tame it with the swash mix.As you progress and confidence builds you can slowly add some to the mix but with 100% DR's you wont want to go above 60-65% as you will get binding.
                ok thanks, so is that +60 or -60 with the swash mix?
                Trex 500l Dominator
                Trex 450l Dominator
                Mcpx bl
                Pheonix sim
                dx8
                  You have to test the swash first, ie use plus to start with and if the swash is moving in the wrong direction change it to a minus
                  Troll buster
                    If you have flown it then you dont need to change anything other than the value.
                      You won't get binding with 100% rates as a beginner. Brown trousers possibly, but not binding.
                      Chris
                      Phoenix Sim
                        ok cheers guys i understand it now thanks
                        Trex 500l Dominator
                        Trex 450l Dominator
                        Mcpx bl
                        Pheonix sim
                        dx8
                          Chris
                          Lol @ brown trousers!
                          Futaba T8FG - Trex 600NSP
