eCCPM versus mCCPM
  • eCCPM versus mCCPM
    Does anyone have a view on whether mechanical CCPM is better than electronic CCPM (via tx mixing) for a beginner? Is eCCPM harder to set up and trim for the beginner, etc?
    I would say mechanical is easier to setup for a learner.
    As far as performance in flight - there are differences, but one of the magazines found it hard to tell the difference between identically kitted Sceadu Evo 50s - one on mCCPM and one on eCCPM.
    I don't know who did the flying...
    | 3D Championship
      As Rob said mCCPM (mechanical) is easier to set up with each servo doing 1 job where as eCCPM is harder and more fiddly to set but all 3 servos share the loads and there tends to be less linkages but more chance of interactions.
      Raptor 50 V3 Titan
      Trex 600N Pro R.I.P
      Knight 3D
      Trex SEV2
        Thanks. In general, what are the most common build / set up errors made by beginners?
          I would guess linkage lengths. They need to be right and sometimes are not, which can cause lots of unwanted issues with flight.
          Twisting the tail drive belt the wrong way.
          Loads of things can be overlooked or go wrong as it's a complex thing to do, but practice, manuals and help from here is all you need really
          | 3D Championship
            i finaly built and flown my x cde eCCPM model apart from a few issues with the tail (that will be another post shortly).
            its my first eCCPM model flies ok few clicks on the cyclic and away she went in the garden.
            must get a new receiver though
              Spike, bang it together and I will give it a once over and help set it up with you. I normally pass through Crystal Palace my friend has an RC shop on Anerly Road (Racing Passion).
              What heli is it BTW?
              Raptor 50 V3 Titan
              Trex 600N Pro R.I.P
              Knight 3D
              Trex SEV2
                firstly this whole mCCPM/eCCPM thing is just being pedantic. you have mechanical where each servo controls each control (2x cyclic and collective) then you have CCPM where you have a servo that controls a ball of the swash plate.
                i think its more a case of mechanical being easier to get it to "fly"
                getting them setup correctly isnt any different between mechananical and CCPM. The trouble is that if you get it wrong on mechanical your ptch curves will be a bit screwy. if you get it wrong on ccpm then you will get interaction.
                imo, no newbe should be left alone to setup and test fly a model there is so much to get wrong its just asking for a hard time. Theres people that have been flying for donkeys that still cant setup a model properly what hope does a noob have?
                Ade
                www.accurc.com
                adrian@accurc.com
                This is an apple free zone
                  I'm with Ade (blimey for once ) there are alot of things to get wrong with setting up any heli (eccpm or mccpm). Get somebody to check it and test it before you try and fly. Its hard enough to learn with a well setup heli, let alone one that doesn't do what you tell it too. One thing that is essential with any eccpm setup, is that its all identical, the 3 servo's are identical, make and model, with identical lengh servo horns and identical lengh push rods. if not and one servo lags the other 2, you gonna be in trouble. I got somebody to fly my sciddly doo after I set it up, and after I have flown it a couple of time's just to see if they noticed anything wrong that my rather lesser experienced hand had missed (Cheers Edders). Its not worth losing you hard earned cash being to keen and crashing cause it wasn't set up properly (been there done that cost me £75 cause i didn't check the pitch range and the heli wouldn't come back down)
                  Patience is essential in this game, or a very deeeeeep wallet and a steely resolve.
                  And a DX8 too
                    People like me are screwed then , ive got no club or local model shop up here that realy entertains helis so I have no option appart to go it alone .
                    Sad realy , would love to have a heli buddy , have to try and get some one hooked . Any way my v2 raptor is mccpm but the night sport is eccpm and I think ill be head scratching for a while , but patience is a virtue and ill not fire it up till im 100% sure its right HOPE . Great thing is this place if there is a prob just post before all hell breaks loose.
                    Just like to say a thank you to all that have solved a lot of my probs in the last 2 - 3 months
                    Regards Jamie
                    REGARDS JAMIE
                    Knight 50,50 hiper,hatori pipe,gy401+9254,ttcarbon blades futaba ff7fast 2.4 ghz set up with 3152 digi s all round and a rev loc 10
                    450 rex standard setup
                    Phoenix sim...
                    Plus two gliders and one pits special biplane
                      I agree with Ade,both systems have good and bad points but i feel that models should be checked and test flown by someone experienced especially 30 size and over
                        if you dont have any local support make a day trip. drive a couple of hours to a club that can help. You dont need to go there all the time but nothing stopping you joining and visiting every month or 2 for a top up. we have a few members like that at DMHC.
                        Ade
                        www.accurc.com
                        adrian@accurc.com
