t vrex 600 esp second ESC faliure
  • t vrex 600 esp second ESC faliure
    just had my second Align 100A esc burn up in flight after 20 no problem flights
    take off all normal a few loops rolls flips inverted
    on my tx timer at 4mins comming in to land total powes loss
    recovered heli and the complete ESC body is a fried alloy backplate with no internals at all
    this is the second Align 100A to fail in very few flights ?
    my set up is DX 7 AR 7000 2.4mAp rx lipo
    Thunder power 5000 30c
    set using throttle high stick beep beep beep plus notes
    the same with low stick
    normal thro curve 7
    35
    72
    85
    idle 1 & 2 are a flat 85
    am i missing something in set up ? before this instance the ESC has been cool to touch as i check immidiatly after each flight HELP
