Neon Blaze Issue
  • Neon Blaze Issue
    Chaps,
    Wondering if you can help.
    I have taken the copter out for only the second time - did not crash it the first time either.
    The issue I have now is that when I turn the throttle up only the tail rotor spins (which is strange in itself).
    Completely confused by this, have been through manual and check transmitter settings, been online and check default controller setup, check RX / TX setup - the thing is binding ok too.
    Has it gone mad?
    cheers in advance.
    George
    Have you checked the motor is still meshed with the gears?
    Sounds obvious but my motor loosened up, after a couple of flights.
