Binding, what's that about then?
  • Binding, what's that about then?
    Hi All,
    So, I'm reading the forums and keep coming across binding.
    What is it, what does it do, how do you do it and what is it used for.
    I only have a simple tx and rx in my twister, obviously this binding is related to much more complex kit but something i do need to know about and learn for the future
    Jamie
    It's the term used to describe the process of linking a 2.4 ghz transmitter (like a spectrum DX8) to a receiver (like a spectrum ar7000). Once the "bind" has been made, the transmitter can recognise the receiver and will then allow the two devices to communicate. There are different ways to bind depending on the transmitter/receiver manufacturer, but the principal is the same. Hope this helps!
    Simon
    BNUC-S certified
      hello mate, hope this helps, when u use 2.4ghz u bind tx to rx and only your machine will work. so no other interferance from other radio's ect,
      Ronnie
      Goblin 700 - HC3sx- Konny Pyro 700-52 - konny 120hv - bls 251 - bls 451s
      Goblin 570 -demon 3sx - konny 100lv - xnova motor - Bk 7001s -BK 7005
      Boggy combat plank - wot 4 - EFX - ECt ECt lol
      FUTABA T14SG
      PMHC - A128FREEFLY - Thurrock model flying club - TTI
      GUINNESS WORLD RECORD PILOT 2012 & 2013
      GRASS ROOTS 1st PLACE, FEB 2013 ( FOR BEST CRASH LOL )
        Right ok. So it's basically just connecting your TX and RX to one another instead of the old crystals!
          Yup. Not to be mixed up with the other type of binding, where servo wheels rub, or arms are driven too far and jam etc
          Harry
          Powered by Futaba 18SZ
            ...or indeed in the legal sense either, ie a legally binding contract.
            Mike
            TRex 600NSP, OS55, MicroBeast
            TRex 500ESP
            Futaba 14SG Optifuel 20%
              Not exactly interference free. What happens in binding is that the Rx is told which Tx to listen to. Or in the case of modelmatch which model in which Tx. You are right that the Rx won't listen to any other Tx or work with any other model, but if there is enough interference it could end up in failsafe.
              Chris
              Blade 130-X, MSR, MSRX
              Phoenix Sim
                So, I read something about whilst in Bind Mode, you can also set up what defaults you want the helicopter to revert to (Failsafe Conditions) when the link is lost?
                What else can you do in this mode? I've never had a fancy TX before so is nice to get a good jist of what they are capable of
                  It depends on the tx and rx. Some spectrum rxs don't do a proper failsafe. They do a smartsafe. Throttle goe to Bind value and other channels hold position. Seems to work ok when you are just hovering.
                  Chris
                  Phoenix Sim
