twister skylift (chinook) problem
  • twister skylift (chinook) problem
    hey guys, i was lucky enogh to have a twister skylift given to me by a mate. with 2 remotes its a 35mhz jobbie,he had a crash with it nothing heavy from what i can see! needs new blades all 8 and he cracked the plastics a bit. the problem i got is when i turn it on! the up and down lever works fine but the throttle side dont work at all.. would this be because ive taken the blades off the heli? in other words the motors wont power up when i give it throttle. the remote and helli connect ok. cant see no damage to the wires or internal bits at all. any ideas guys..the 2 remotes are model e8,but 1 has servo reverser on it the last 1 is binded to it cheers for your help yet again peeps
    Hello DAGZ,
    I don't know the skylift personally, but I believe you need to ensure the throttle and the throttle trim are all the way down before you connect up the battery. Otherwise the ESC will not initiate and the motors will be disabled.
    Graham
    Phoenix, DX6i.
    x2
      Yep agree, on mine I have to have throttle trim all the way down.
      • Flickr Through My Pictures.
        hey guys cheers for that,just checked what you told me! and got the motors going now,but for some reason the throttle works back to front.
        the trim got to be all the way in the up position and the trim also so when i push down on the stick it revs up
          You need to reverse the throttle channel in the transmitter
          Graham
          Phoenix, DX6i.
          x2
            I'll second that aswell
              Originally posted by tiddler View Post
              Hello DAGZ,
              I've had one for ages bit tricky in flight but fun, have a
              howitzer to sling under pick up/drop on my one
              GAUI X7 Beast X V3 (a nice bit of fish!)
              Trex600n Fbl ys56sr BeastX V3
              Trex500Fbl AR7200BX
              Trex500 Apache x4bld BeastX. Trex 600E HIND mil x5bld BeastX
              DX7se
                cheers again guys! there is some switches on the bottom right face! so ill flick them and try it they say servo reverse on them? or do i have to open the transmitter..top guys cheers
                  Be careful when changing throttle direction. Best to take the blades off first
                  Graham
                  Phoenix, DX6i.
                  x2
