RC Booya Canopy Mount for Trex 550e
  • RC Booya Canopy Mount for Trex 550e
    Hi - I'm thinking of purchasing the RC Booya quick release canopy mount for my Trex 550e ... 550 Series -
    According to the website ...
    Use of this kit requires you to increase the canopy mounting holes on your canopy to 11/32 diameter to install the grommets.
    How easy is it to enlarge the canopy holes? Can fibreglass just be sanded with some fine sandpaper? I don't have any specific tools such as a dremmel for this, and don't want to buy any.
    Your advice appreciated.
    You could use a round file I guess - but a canopy reamer is made for this exact job
    And here's the RC Booya mounts for the Trex 550
    | 3D Championship
      You only need to ream the holes out a little, do it a bit at a time see if they fit each time.
      Phil
      Phil's little world
      Mikado 500se - Align T-Rex 450L Dominator 6S - E-Flite Blade 350 QX2
        They are great mounts.. simply the best IMO and yes, you have to increase the canopy hole, I use a dremmel with the taper cone drill piece, does it a treat and keeps it a proper circle! If you havn't got a dremmel, then like Rob says a file should work fine!
        http://www.dremeleurope.com/dremeloc...483&prod_id=96
        Eddie
        Velocity 90 FBL BeastX V3
        Trex 600 LE FBL BeastX V3
        Trex 500 EFL Pro BeastX V3
        Fusion 50 FBL
        VBar
        All powered by a DX8
          If you don't have any tools just roll up some sandpaper and push through the hole and rotate.
          ..another tip is to use the 600 rubber canopy mounts. mount them in front of the two el/pitch servos, this will push the canopy away from the servo arms.
          Phil
          Phil's little world
            OK, thanks for input. Sandpaper (fine, I presume?) around a pencil it is, then, as long as we're sure that will work on fibreglass.
            I really can't justify £20 mounts and then a reamer or dremmel - my wife is already beginning to wonder the cost of all the parcels that have been arriving recently.
            And I haven't even got the lipos, charger or powersupply yet!
              lol.. its expensive and addictive isnt it!
              Dont scrimp on a charger.. get a decent one Not saying theres anything wrong with cheap chargers but it just takes forever..
              Eddie
              Fusion 50 FBL
              VBar
                Am I allowed to hijack my own thread???
                So I'm considering this PS ... Rapid Electronics - Electrical & Power > Power Supplies > Bench PSUs ...
                ... and the 1,000W iCharger 306B.
                Issue is of course the price, but I'm really trying to future proof my purchases so I don't have to keep spending (hence i decided on a FBL 550e with mini vbar blueline express 5.0).
                All thoughts gratefully received.
                  Perfect, just what I needed.
                  Mounts for the 550 as the standard ones are poop and dont want the stock canopy to go on.
                  And the reamer to enlarge the holes properly on my Srimok canopy from Fusano
                  Ordered both
                    I like the look of these, didn't know they existed, thanks might get a set for my 600 n as well. Shame they don't do a set for the 450
                    Trex 600n Ltd Edition Spectrum DX7
                    Trex 550E Super Combo
                    Trex 450 Pro Super combo
                    Blade 120 SR (Bnf)
                    Max Thrust RIOT (55 PnP)
                    'Turn your Potential into tommorows success'
                      Originally posted by alistair.howie View Post
                      The charger is cool but you can save alot off pennies with the psu by making your own out of server psu's around £25 in costs
                      http://www.rcheliaddict.co.uk/batteries-chargers/49570-homemade-2000-watts-portable-charging-station.html
                      http://www.rcheliaddict.co.uk/batteries-chargers/44778-server-psu-600watts-25-a.html
                      Doesnt matter they dont make them for the 450.. If you wanted a set.. you can make them fit.. Make sure you get the T600/700 front ones as they are the shortest ones.. They dont make them for the V90 but I've got a dremel out and made a set fit. I had to trim the mounts down drill a new hole and add a bolt through on the V90
                      Eddie
                      Fusion 50 FBL
                      VBar
                        Thanks, Eddie - am aware of the PSU route but I have absolutely zero electrical skills to go down that route, I'm afraid. Am at the edge of my abilities learning soldering!
                          I have done exactly the same on Shaun's Velocity 90 - much better than the standard pins and grommets!
                          Proud Sponsor/Pitman/Servant/Slave to Bart101s fleet of Outrage and Avant helicopters
                          Bart101 suffers from a medical condition called "Compulsive Inpulsive HeliAddict"
                          sigpic X3
                            Great minds think alike Dave!
                            Eddie
                            Fusion 50 FBL
                            VBar
                              I've fitted the rc Booya mounts to my 550e and didn't have to alter the holes in the canopy.
                              Must say it's a lot easier to fit the canopy now and seems very secure.
                              RCHA - Guinness World Record Pilot 2011/12/13 Central Model Helicopter Club
                              Some helis were damaged during the making of this signature.....
