Honey Bee cp2 help
  • Honey Bee cp2 help
    i am new to this hobby, i started with a 3.5 ch indoor heli and can fly that no bother i then got myself a HonryBee cp2 but cany seem to get it off ground.
    The heli keeps spinning left. (Nose going left, tail going right)
    Can any1 help me out with this please.
    Love Music Production work as i produce Dance music but im reali getting into Rc Heli's. I have couple beginner heli's / phoenix sim & Im now looking to buy a Trex 600 Nitro.
    Try reversing the gyro, it will have a normal/reverse button on itI would of thought.
    Sab Goblin 500
      i have tried that and still same prob
        The spinning comes because there is an imbalance between the drag from the main rotor and the countering thrust the tail rotor produces.
        If I remember correctly, the CP2 has a "proportion" pot (the one NOT marked "Gain") that controls how much of the throttle power setting is passed to the tail (as increasing throttle power setting will increase the drag on the main rotors, and so need more thrust from the tail). Try increasing this.
        Good luck, you'll need it! :-)
        Neil H: Certified compatible.
          How fast is it turning? If it's rapid then the gyro may need reversing, if it's slow it's probably a duff tail motor, they sometimes last only a couple of flights, I even had brand new ones that were duff. A good one will last maybe 20 flights as long as it doesn't take a knock!
          Mikes Place - Home of the golden dump.
          Sponsored by Elite Models.
          http://www.elitemodelsonline.co.uk/
            it turns fast i have tried reversing gyro.
            i put a new tail moter on but its the same make as before
              You haven't tried reversing the gyro, because (IIRC) that's not possible with the CP2 (the gyro, speed controller and receiver are all one unit). What you've tried doing (I suspect) is reversing the rudder stick direction.
              It is possible (especially if you've changed the motor) that the tail rotor is now turning the wrong way. It should be blowing air to the right (trying to push the tail to the left); the tail blades should come "up" towards the front of the helicopter.
                sorry but wat do u mean by he tail blades should come "up" towards the front of the helicopter
                  Hi,
                  Best diagram I could find:
                  If I remember correctly, the CP2 tail rotor is a single moulded piece that can only go on one way. If everything it working correctly, it should blow air to the right.
                    ya it runs same as this but still nothin. does any1 fix these?
