ref twister
  • ref twister
    hi guys ive got an indoor twister pro ive just crashed it everything looks ok nothing broken but when i hover it it wobbles all over the place any ideas please
    bent main shaft?
      there are lots of possibility. double check everything, your main shaft, tail shaft, feathering shaft etc.
      MSH Mini Prรดtos Stretch FBL 4s
      Msh 2010kv motor - YGE 60 - ​Hitec 5065MG - BeastX - BLS257
      Futaba 8FG - Mode 3
        Take the main shaft out and roll it along a flat surface. It will probably be bent. I know you have an indoor heli at the moment but almost every larger heli crash bends the main shaft the feathering shaft and the rotor blades for starters. This will produce loads of vibration which will destroy the rest of the heli. As others said there are lots of other possibilities as well.
        Chris
        Blade 130-X, MSR, MSRX
        Phoenix Sim
