Flasher 250 spinning
  • Flasher 250 spinning
    Hello, i took my flasher 250 out for a test flight today, throttling up everything seemed fine, but as soon as it got light on the skids, lifting off, the heli violently started spinning to the left, pirouetting about 540 degrees before i could get it back down. tried trimming the heli, but still the same problem.
    Anyone got any ideas on how to sort this, as im very new to all this.
    I used the search function, but couldnt find this same problem.
    Thank you, conan.
    Sounds like you need to reverse your gyro!
    Sam
      Ok, il give this a go, wont be able to find out if its fixed till tonight though, as have to go work now , thanks for the speedy reply
        Possibly linkage wrong length for tail, or tail hasn't been set up correctly
        Kev
          take a look at this link
          http://www.phoenixtechuk.com/v2/acce...tor_set_up.pdf
          it will help.
          andy
          The UK's sole distributor of MKS Servos
          www.mks-servo.co.uk
          We are here to listen and support heli community
          regards
          andy jiang
            Thank you vanquish, it was simply I needed to reverse the gyro, had a lot of fun with the heli today
              The strange thing is, I had to set the gyro to normal, not reverse how I had set it up to the link andy posted, why would mine be different to the instructions you posted andy? Thanks, Conan.
