Hello
I'm just about to embark on the build of my very first RC helicopter - a TREX 550e FBL. I've downloaded two separate sets of build videos from the internet and some am about ready to give it a go, but have a few (probably obvious) questions about the build. ...
1) Most of the build seems to be done using the supplied T43 threadlock. In simple language please, what's the difference between the T43, R48 and self-furnished CA glue? Is it speed of curing? Are all CA glues alike, or should I buy a particular type? I presume the supplied T43 and R48 are adequate for the job, or should I be using some others? Which?
2) Are the Align made hex drivers of decent quality, or do I need to pay more for some better quality ones? Please suggest any suitable alternatives if you think it's necessary.
3) The instructions say that I need 3mm and 1.8mm diameter Phillips screwdrivers, but I'm struggling to see find such sizes. Instead, drivers seem to be described using a size code 00, 000 etc. What code size should I look to buy? Please suggest any suitable brands if you can.
4) Where the factory has preassembled parts, I know I need to take them apart and re-do with glue. If I can't easily take them apart, do I presume they have been glued in and are ok as is, or will my attempts at taking them apart mean that I have loosened the glue? If they are glued and need to come apart, does this mean I need to buy a soldering iron to do the heating?
5) I guess I'll need a soldering iron anyway once I get my head around the various types of connectors on the BEC, ESC, motor, battery? If so, what should I look for? Specifically, what power rating? If you can suggest a particular model, I'd appreciate it.
6) Will I need to purchase a blade balancing tool, or will my stock 520 carbon blades be fine out of the box?
Probably a bit scary that I've actually taken the plunge in buying this helicopter and don't know these answers, but I guess I've got to start somewhere!
Thanks in advance for the comments/advice.
