I know this is most likely been asked before, but can you change your gyro mode from HH to rate mode while in flight by using your transmitter. As i notice on the sim it far easier doing simple circuits like figure of 8's, while the gyro is in rate mode. Then have it in HH for hovering etc.
Just a quick gyro question
Liam
T-rex 700 LE- V-bar 5.2 | OS91 HZ | 3xDS610 | Tail DS650 | Switchglo Pro | Radix 710s
T-rex 600 LE- OS 50 Hyper | 3xDS610 | Tail DS620 | GP 750 | Align Blades
Outrage Fusion 50-BeastX | Scorpion Motor with Kontronik Jazz
Blade MCP X
Spektrum DX8
Phoenix with SimstickTags: None
Yes you can, but when it comes to flying real RC helicopters, it is unlikely that you will ever want to. Rate mode can be used to establish a really accurate centre tail during the model setup flights, but other than that is pretty much redundant these days.JR Vibe Fifty fb (YS56)
It just seems that much easier doin fast forward flight using rate mode. So would you suggest i dont get used too it and stick too just HH. I never knew it was possible as i thought you had too have specific type of gyro for each modeLiam
Blade MCP X
Spektrum DX8
Much better to learn to fly the tail tbh. I would stick to HH if I was you
Ok doke, rate mode off!Liam
Blade MCP X
Spektrum DX8
