Hirobo woes
  • Hirobo woes
    Hi All,
    H.N.Y.
    I have owned a shuttle plus for 3years..
    Never did things right, crashed it both times i took it out - to be expected really!!
    So, a bit wiser and lighter in the pocket..i brought a SIM that i connect my RD6000 to..Ive used that for the last 18mths on and off - but heavilly the last few months as i want to have another go .. with the heli
    So started looking at my shuttle to get it airworthy again..
    Its a Shuttle Plus
    No tail (only boom)
    OS32 Engine
    I have came up against some issues that i could do with help on..
    The last crash, the engine reved high until i could cut it..
    Since then I have had it running (12 mths ago) but mid throttle it spluttered as thou it was too rich..carb was set to factory default..
    I noticed a leak on the head so removed the head, cleaned it and noticed that the liner was discoloured down one side (probably thru standing) some fuel had eaten the coating away? - there is a ridge - maybe 4thou\.1mm even less on the liner wall where the discolouration meets the coating?..
    Is this bad ? - the engine hasnt done a lot of work as it was new when i had it.
    secondly, the shuttle minus tail .. whats the best option here - upgrade it to shuttle plus 2 tail, a quick UK alloy one, a cheap ZXX one off ebay?
    Ive got loads more questions but need to start here first...
    Im really hoping if and when i get in a position again, itll be different with the help of the SIM and a club im intending to join...(i used to be in sutton when i first started but never got to use my membership)
    thanks
    Rich
    I would fix it with original parts. The ridge sounds like a tide mark where the oil has settled. I would strip the engine, use carb cleaner from a motor factor and clean it out. Re-assemble and then set everything to factory to get it running again. Doing that with the engine will give you a chance to check the liner and ring and maybe change the bearings at the same time.
      i would also replace the head gasket
      with the tail if you find one cheap enough get a used one off ebay
      but do check the price of the new parts before you bid on anything
      Hirobo Turbulence D3
      1/4 scale Vario Bell 47 G3
      1/3 scale Vario R22
      2012 LHC Scale Cup Judge
        yes, I should have mentioned that was the reason why i initially had the head off - to replace the gasket on advice from midland..
        The marks on the liner wall definately looks like slight errosion rather than a deposit...
        The reason i also mentioned about the tail options was that I beleive this was an upgrade from plus to plus2?.
        I have seen a complete case assembly on ebay in "good nick" for the ZXX cheaper than just a couple of tail parts for the PLUS \ PLUS2..
        I just dont know how much of an improvement this upgrade made?..
        I think i just want to get it operational at moment and if the SIM training pays off, consider my options on where i want to spend at a later date..
        Rich
          The only thing I can think is that it's rusted somehow. Can you get a couple of pics up, might help.
            the plus 2 is running a sceadu type tail box, you won't notice any difference in flight from the zts/zxx box
            with the liner i would use some fine grade wet and dry with a little oil and just break the glaze on the liner (don't go mad and don't try to get the marks out) and reassemble and try it
            1/3 scale Vario R22
              thanks guys..advice has gave me a good start..
              Rich
