what is used to connect wire to tailmotor. i tryed using soilder but didnt work.
help plz
Hmm what else would you use super glue ?
So what model pics more info perhaps would help :0)
Sent from my iPhone using TapatalkKel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
& JR DSX11 ,Phoenix and a fridge full of bottled water
RCHA Courier Services PM for Details
www.parcelshipper.co.uk and www.impactexpress.co.uk
Welcome to the forum ryan maybe you should introduce your self in your 1st post and also try to supply more info to make it easier for the guys here to be able to help you
Gaza07
Trex 500esp 6s Beast-X V3
Trex 600esp 12s Beast-X V3
A few Multi Rotors
Looks like you need to improve your soldering skills thenOriginally posted by RYAN CAIRNS View Postwhat is used to connect wire to tailmotor. i tryed using soilder but didnt work.
lol ya i think the same.Originally posted by tiddler View PostLooks like you need to improve your soldering skills then
Love Music Production work as i produce Dance music but im reali getting into Rc Heli's. I have couple beginner heli's / phoenix sim & Im now looking to buy a Trex 600 Nitro.
You can find lots of tips for soldering on you tube the main thing is make sure every thing is very clean & tin both items, Also the right soldering iron and solder
Gaza07
A few Multi Rotors
I am not familiar with the model but is the wire laquered rather than sleeved? this can catch out the unaware as the laquer needs to be scraped off prior to soldering.
Either way tin the wire then solder it - get a good iron and use 60/40 leaded solder with rosin flux cores.Rob
Futaba 9CP & 10CG
