T Rex 450 SEV2 belt drive wheel replacement
  • T Rex 450 SEV2 belt drive wheel replacement
    Not sure where to put this, but as a newby, here'll do ?
    The belt drive wheel ( alloy) was loose on it's shaft, a hard push and"click" down it went, feels tight but I want to replace it. The new assembly is in two parts, the small alloy wheel appears to be an interference fit mid shaft. Don't have a manual, so how is it all put together folks ?
    Trex 450 SEV2.
    You can find the manual here as a PDF http://rvmhc.com/manuals/450SE%20New%20V2.pdf
    You have a strong will, but a weak won't.
    Tempus Fugit
    even when you don't.
      manual here if it helps.... Links and Downloads Manager - Helicopter Manuals - RcHeliaddict
      (beat me to it )
      Mcpx
      Trex 250
      Trex 450 Pro
      Hirobo falcon 505
      ElyQ V50
        Thanks fellas, but that manual I do have. It shows the assembly as a complete unit. Replacement is a two part as I mentioned in the OP. No idea what to use to assemble this into the heli, I'm guessing a push fit to line up the teeth and wetting the shaft with medium thread lock, but ain't sure.
        Trex 450 SEV2.
          If you are talking about this item,
          When I bought one it came complete as one unit.
          Don
          Heinz 450seV2 Pro
          HK 500 GT
          Phoenix
          Spektrum DX6i
            Mine like so http://www.fast-lad.co.uk/store/hs12...ly-p-1818.html Makes yer larf dunnit. Been suggested to use epoxy or green loctite. Thanks Don.
            Trex 450 SEV2.
              I believe that is for the sport or pro where I think the bearing block is in two halves.
              The V1 and possibly the V2 has a single piece bearing block so the bearing and shaft have to be fitted to it before the drive wheel goes on.
              In response to the OPs question. You don't want this pulley to slip in flight so it may be worth using some green loctite on the pulley when fitting it instead of relying on the interference fit alone.
              Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
                Thanks for that Bolder. The V2 has a one piece lower block and a two piece upper by the way so the unit could be used either way. Do you know if the sport and pro unit has a different gear ratio compared with the V2 ? I don't want to fit and find it's not right for my beginners reactions.
                Trex 450 SEV2.
