Flybarless helicopter?
  • Flybarless helicopter?
    Hi,
    Quick question,
    Is it possible to get a mini helicopter without a fly bar?
    what do you mean by mini? trex250, 450 ?
    i dunno
    matty
    Spektrum DX7s
    DJI F450 naza/gps Trex 500
      around the blade msr or blade sr size? They would look so much better when landed etc.
        if you hit a wall hard enough it'll land without one lol. the answer is no the only type without a flybar at that size would be a coaxial heli like the mcx
          Almost done that enough times
          What would happen if you took the flybar of the msr? how long would it take to crash?
            Actually I think there is a flybarless version of one of the little Walkera helis; about the same size as the mSR, maybe a bit bigger.
            Neil H: Certified compatible.
              Walkera V400D02 Flybarless 6 Channels 2.4G Helicopter on eBay (end time 13-Nov-10 09:04:27 GMT)
              x 3
                tht looks quite good for a walkera
                Chris 'CHUNK' Newby
                ALIGN-TREX.CO.UK team pilot
                LYNX team pilot
                SPARTAN team pilot
                Dx18
                  Something does not quite add up
                  635mm main rotor diameter, 60mm length, weight about half a kilo?
                  Synergy N5C with 3GX on the bench
                  Trex 500 ESP FBL BeastX -soooooooooo fast
                  Trex 700 LE Beast X'd and no sticky out bits
                  Velocity 90 BeastX FBL-the love affair has begun!
                  Newton Abbot Heli CLub where the sun always shines
                    the rotor is ten times bigger than the model in tht case and its so shit and flimsy it only weighs 500g or so
                    Chris 'CHUNK' Newby
                    LYNX team pilot
                    SPARTAN team pilot
                    Dx18
                      I just looked, Walkera do a whole heap of flybarless ones now! (How well they fly is a different question...)
                      Have a look here: Remote Control Helicopters ; scroll down to the helicopter list at the bottom left.
                        Thanks for searching, something like the v120D02 looks like something im after. WIll have to try and find a uk dealer.
                        They look so much better as they then look identical to real helicopters, sort off.
                          Wakera's 4F200 16.5" FBL 3-blader uses a belt driven tail as opposed to the motor or shaft driven tails of so many of it's mini helis.
                          WALKERA--CHINA
                          Koz
                          Total Relative noob
