Hi all,
I have recently replaced the sc32hr engine in my shuttle with a Webra 35 competition. I have the main needle screwed out 2 turns and have not adjusted the idle setting. the plug is working fine. fuel has 5% nitro (Morgan Fuels). Throttle servo operates from stop to stop. The problem- The engine is just refusing to run. I opened the throttle further by setting the trim tab to full and stick at bottom the engine ran with very little smoke and stopped as soon as the throttle setting was reduced. I don't want to try again in case the screws are way off and I cause damage to the engine. Has anyone experience with this engine or no what neddle settings to start with. I am a novice when it comes to model engines and I would be grateful for any advice.
regards,
Fergus
regards,
Fergus
