Progressing to idle up advice for a noob
  • Progressing to idle up advice for a noob
    Hi all,
    Although I'm not brilliant, I can now hover not too bad with the occasional panic! But think that I should start practising in idle up mode. I've a Trex 500 with DX6i TX.
    What are your thoughts? Should I stick to normal mode until I'm more proficient or move on to idle up mode. What settings should I start with in idle up.
    TIA
    Daz
    Stick with norm mode for now & practice working on nose-in once you've mastered that your be ready to start thinking about some 3d stuff then your need idle up.
    • Flickr Through My Pictures.
      I would keep to normal mode for now but perhaps change pitch so your now hovering at 3/4 stick position and keep practicing hovering at that
      Cheers Paul
      Avant Aurora fbl
      Synergy N9 ys91srs
        Yup, stick with normal mode for now, but get used to having 0 pitch at mid stick. Then when you do progress to idle up, things wont feel so different.
        Graham
        Phoenix, DX6i.
        x2
          Agreed- it feels really strange when you have different pitch curves- well worth getting used to o pitch at mid stick ie make sure your curves/lines for pitch always go through 50 at mid stick.
          You could also gradually increase the head speed on the 500.
          Synergy N5C with 3GX on the bench
          Trex 500 ESP FBL BeastX -soooooooooo fast
          Trex 700 LE Beast X'd and no sticky out bits
          Velocity 90 BeastX FBL-the love affair has begun!
          Newton Abbot Heli CLub where the sun always shines
            I already have 0 degree pitch at centre and hover around 3/4 stick.
              you don't really need to be in idle up unless your flying around, keep practicing the hovering till your 100% confident with it then start moving the heli around abit lazy 8s etc, then think about idle up when your doing fast forward flight
              thats how i learn't anyway one step at a time
              Cheers Paul
              Avant Aurora fbl
              Synergy N9 ys91srs
                sooner you can get into idle up the better really, i hate flying in normal mode, only really happy when gov is engaged and in idle up 1 atleast. my level is basic aerobatics and ff with some flips rolls and loops.
                Trex 700 LE
                Trex 600 LE
                Trex 450 Pro
                DSX 9
                www.midlandhelicopterclub.org.uk
