hi folks, Im a complete noob with the technical side of rc heli's. Ive flown a few 4ch helis, mainly co-ax, and am fairly competent at flying them, so I bought a Walkera 43Q cobra single rotor heli. It is extremely sensitive and ive already had to replace a few minor parts on it due to not being able to control it as well as the co-ax's. I fully understand the importance of having the heli setup correct before flying, but there are some things i am uncertain about. My main query is that when i have the heli up and in a hover, it seems to sit slightly tilted to the right ( on its vertical axis) when viewed from behind. Ive been told this is normal for a small heli? Similarly, when hovering, if the blades are level to the horizon, the flybar isnt level, and is tilted slighty to the right ( the 2 circles created from the spinning parts are evident on the right but on the left it mix's to 1 blurry circle). Is this caused by the right tilt on the heli or is this the cause of the right tilt on the heli? Im pretty sure my swashplate is level, the flybar is balanced and the paddles are level. Also pretty sure the CG is OK.
It might be that im just rubbish at controlling it, but it seems that when i yaw the heli, it also drifts off quickly in the direction of the yaw. Ive tried keeping it in a steady hover and then performing a couple of quick pirouets, but instead of spinning on the spot it drifts off.
I would greatly appreciate if someone who knows these little things could tell me if there are things needing fixed with the heli or if this is the way it is and i just cant fly it.
thanks for any help,
cheers,
Liam
cheers,
Liam
