hello one and all, ive just finished putting back together my new heli...dont know of brand, might be a hk or exi but not sure what version. why cant you buy them in kit form any more...you are always told to check all screws an artf models and this means a basic rebuild anyway, and i always think you get a better understanding of what goes on if you build em yourself ( im an old balsa basher )...but anyway..i digress.
i need help on getting -2, 5/6, 9 on the pitch in normal mode..i'll worry about the other modes when i feel more confident in the hover, because at the moment i cant get rid of the 10deg neg pitch, i only want to be able to hover at 80 power as a new motor im getting packs a punch that i dont require yet and i dont want to dig my new heli into the ground if i panic, swash-plate is level and the servos are set at 90, all seems to be nice and straight, had a bit of servo 'bump' not bind at bottom travel but found that pitch and throttle curves were not matching each other...have tried adjusting the PL ( full low stick ) but it does not seem to increase the pitch from almost -9 to anywhere near -2. just noticed the fly-bar is not absolutely level, will sort this out but i dont think this is causing my trouble. i am probably one of the last few flying on 35meg, have never had any probs, tx is an sanwa rd6000 super with a hitec hfs-06mt rx, gyro is a gaz-126, speed cont is a 45amp flight tech (yes i know its big, but its what ive got atm) and i trust all this in my planks 110%
all the best, rob
ps..helis are
, no more ic cars, they only work in two planes
all the best, rob
ps..helis are
